I’ve programmed boards before, but I’m concerned about IO pin count - NOVA has 9 vs 22 on BASIC2. My son is interested in electronics, and I’d like to build a smart vehicle project using your tutorials. We plan to use an ultrasonic sensor for obstacle detection, a servo motor for steering, motors for propulsion, possibly an accelerometer to measure acceleration, and an SD card to log events. Can I connect all these devices to NOVA? For the ultrasonic sensor, would I need to add a logic level converter since it operates at 5V?
Originally submitted via email support on 22 August 2016. Migrated to the forum for community visibility.
NOVA has a 5V pin powered by the CP2102 bridge that you can use to power modules requiring 5V. Of the sensors you mentioned, the only one sending a signal back to NOVA is the ultrasonic module - it returns a +5V signal, so it’s a good idea to connect the module’s ECHO pin through a 1kΩ resistor.
You can expand IO pins using shift registers, which are a standard part of our sets: https://e-radionica.com/hr/blog/2015/08/19/shift-registri/
Croduino NOVA ima 5V pin, ali on s s CP2102 bridga te s njega možete napajati module kojima je potrebno +5V za rad. Jedini od senzora koje ste spomenuli, a da šalje signal nazad NOVI, je ultrazvučni modul. On će vratiti +5V signal pa ne bi bilo loše ta daj pin module (ECHO) spojite preko 1kohm otpornika.
I/O pinove možete proširiti preko shift registra, koji su standardni dio naših setova: https://e-radionica.com/hr/blog/2015/08/19/shift-registri/
