Croduino NOVA WiFi control for 5 motorized blinds via smartphone
I need a complete setup to control 5 motorized blinds with WiFi via raise/lower commands from a smartphone or tablet. I’m looking for either a controller with USB power or a 220V AC/DC power supply integrated into the board. Can you also provide instructions for downloading the mobile app?
Da imaju na sebi ispravljac onda bi bolje uzeo taj model. Lp…Hvala
Originally submitted via email support on 13 March 2018. Migrated to the forum for community visibility.
For this project, I recommend the Croduino NOVA as your controller. You’ll need a power supply - either a 5V/2A USB supply or an AC/DC mini power supply with 5V/700mA output.
For controlling the blinds themselves, you’ll need to plan how to operate the motors or actuators - have you thought about that part yet?
Here are the relevant guides for NOVA:
hvala na upitu!
Kao što smo pričali na telefon, kao kontroler preporučam Croduino NOVA: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
trebate napajanje: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
ili: Jedinične napajanja | Pouzdani izvori napajanja – Soldered Electronics
nešto za kontrolu roletni, jeste li to već smislili kako odraditi?
i onda naravno nešto za upravljanjem motorom(ili čime već što pomiče roletne)
za NOVU:
upute za programiranje: https://e-radionica.com/hr/blog/2016/01/31/kako-programirati-croduino-nova-iz-arduino-softwarea/
primjer koda koji otvara web stranicu: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
umrežavanje NOVA + smartphone: https://e-radionica.com/hr/blog/2018/01/25/blynk-croduino-nova-dio-13/
So for controlling 5 motorized blinds with raise/lower via smartphone or tablet on Android, I need the Croduino NOVA with either USB power or 220V/5V mini power supply. Then I download the Blynk app on the tablet.
What I need to understand:
  • Which outputs on the board are for the motors controlling the blinds, and how many total outputs does the board have?
  • When controlling via tablet or phone, do I need to enter code the same way as on a computer, or is it much simpler?
Znaci da bi upravljao sa roletnema dizanje/spuštanje u mojem slucaju sa 5kom,preko smartphone/tableta android platforma potrebna mi je Croduino nova sa napajanjem preko usb ili napajanje 220V/5V mini.Nakon toga “skinem” aplikaciju Blynk na tablet!
–Nije mi jasno koji su izlazi za motor (za rolete)te koliko imam izlaza na kartici?
–Još me zanima kad se upravlja preko tableta ili mob. Dali je potrebno isto tako unosit one kodove kao i na kompjuteru ili je sve to puno jednostavnije??
Lp,hvala..
Yes, you need the Croduino NOVA with a power supply at 5V or 3.3V, for example:
The NOVA has 11 I/O pins (outputs). You’ll need relays to control your blinds: https://e-radionica.com/hr/moduli-aktuatori/releji.html
You can set up control via phone/tablet through a graphical interface using Blynk. Here are the instructions: https://e-radionica.com/hr/blog/2018/01/25/blynk-croduino-nova-dio-13/
With this tutorial, you don’t need to do anything differently - turning on an LED is identical to turning on a relay.
tako je, trebate Croduino NOVA i napajanje, na 5V ili 3.3V. npr.:
NOVA ima 11 I/O pinova, tj. izlaza. Trebat ćete releje za kontrolu roleta: https://e-radionica.com/hr/moduli-aktuatori/releji.html
možete napraviti da upravljanje bude preko mobitela/tableta preko nekog grafičkog sučelja, npr. Blynk. evo ovdje su upute: https://e-radionica.com/hr/blog/2018/01/25/blynk-croduino-nova-dio-13/
dakle od ovog tutorijala ni ne morate ići jer je paljenje LEDice identično kao i paljenje releja
