Croduino Nova32 USB 5V and +5V pin simultaneous connection
Can I connect USB 5V and also supply voltage to the +5V pin simultaneously? Could you please send the pinout and schematic for the Croduino Nova32?
zanima me mogu li se istovremeno spojiti USB 5V i i dovesti napon na pin +5V, odnosno, najbolje bi bilo da mi pošljete molim pinout i shemu za CRODUINO NOVA32.
Zahvaljujem.
s.[name removed]
Originally submitted via email support on 1 July 2020. Migrated to the forum for community visibility.
This is completely unacceptable. Pinout in development for months? Why did you put a device up for sale that you’re not able to provide documentation for?
potpuno neprihvatljivo …pinout u izradi mjesecima? Zažto ste uopće stavili u prodaju uređaj za koji niste u mogučnosti priložiti dokumentaciju?
L.P.
s.s.
Regarding your question from the first message: do not connect 5V and USB voltage simultaneously, as they are the same line and you would be connecting two power sources in parallel that way.
žao nam je zbog toga i ispričavamo se, ostali smo bez dizajnera.
Što se tiče Vašeg pitanja iz prvog emaila, nemojte istovremeno spajati 5V i USB napon, s obzirom da su isti vod te ćete paralelno spojiti dva izvora na taj način.
Please send me at least the schematic so I don’t waste more time on this. You must have it. It’s a shame you didn’t separate the power supply from USB and +5V.
hajde mi pošaljite barem shemu na mail da ne gubim vrijeme s tim barem. Sigurno je imate. Šteta što niste razdvojili napajanja od USBa i +5V.
LP- s.[name removed]
The schematic and original Eagle files are attached.
naravno, shema i originalni Eagle fajlovi nalaze se u privitku.
Attachment omitted in migration: Croduino Nova v2.0 Schematics.pdf
Attachment omitted in migration: Croduino Nova v2.0.brd
Attachment omitted in migration: Croduino Nova v2.0.sch
I apologize, I didn’t specify in my last message that I have Nova32 boards. Could you please send those if it’s not a problem?
ispričavam se nisam naveo u zadnjem mailu, ali imam NOVA32 pločice, pa ako nije problem da to pošaljete.
L.P.
s.[name removed]
I apologize for the mistake. I sent the wrong files. Now the Nova32 should be in the attachment.
Ja se ispričavam, krivo sam greškom poslao. Sada bi trebao biti NOVA32 u privitku.
Attachment omitted in migration: Croduino_Nova32.brd
Attachment omitted in migration: Croduino_Nova32.pdf
Attachment omitted in migration: Croduino_Nova32.sch
