Where can I find instructions for programming the Pico board? How do I connect it to a PC for programming? Is there a tutorial?
Pozdrav. Molim vas link na uputstva kako programirati pico plocicu? Kako da je spojim na pc za programiranje? Ima li tutorial?
Hvala
Originally submitted via email support on 26 January 2017. Migrated to the forum for community visibility.
Would you be programming it with another Arduino or with a USB to TTL adapter?
programirali biste s drugim Arduinom ili nekim USB to TTL adapterom?
With Arduino Basic2 if possible.
S arduino basic2 ako je izvedivo
Hvala
Yes, that works.
Connect the boards:
Basic2 → Pico
+5V → +5V
gnd → gnd
Tx → Tx
Rx → Rx
reset(rst) → gnd
Set up Arduino IDE the same way you would for programming Basic2.
Press the reset button on the Pico board.
Click Upload in Arduino IDE.
Release the reset button when “Uploading…” appears in Arduino IDE.
Naravno.
Povežite pločice:
Basic2 → Pico
+5V → +5V
gnd → gnd
Tx → Tx
Rx → Rx
reset(rst) → gnd
Arduino IDE postavite kako biste inače programirali Basic2
Pritisnite reset tipku na Pico pločice
Stisnite Uplad u Arduino IDE
Pustite reset tipku kada se u Arduino IDE pojavi Uplading…
Ukoliko trebate precizniju pomoć slobodno javite.
I got the answer, understood everything clearly. One more question if I may - I have an RGB LED connected to the board. When booting, clearly before setup() runs, the LED lights up white for about 1.5s. After setup() executes, it lights up in the color I want.
I’m assuming Croduino sets all pins to high when resetting/booting? Am I right? Can this be avoided?
The LED isn’t critical, but I’m planning to add relays and an RF transmitter, and I wouldn’t want clicking during board boot when I’d prefer the pins to be low.
Dobio sam odgovor, sve shvatio, precizno, hvala vam puno.
Ako smijem jos jedno pitanje - imam na plocicu spojenu rgb diodu. Pri butanju, ocito prije pokretanja setup(), dioda zasvijetli na cca 1.5s bijelo. Po izvrsavanju setup() zasvijetli bojom koju zelim.
Pretpostavljam da croduino prilikom reset/boot sve pinove stavi u high? Jesam li u pravu? Moze li se to izbjeci?
Nije mi dioda toliko bitna, ali planiram staviti releje i rf transmitter i ne bih volio klackanje prilikom boota plocice, kad bih volio da su pinovi low
Hvala
Which pins do you have the LED connected to?
na koje pinove ste spojili diodu?
On digital pins, PWM, 0, 1, and 2.
Na digitalne, pwm, 0, 1 i 2
We recommend not using pins 0 and 1 at all because they are used for serial communication with the computer and will activate during every boot or reset of the board.
Also, PWM pins are marked with the “~” symbol. On Croduino Basic boards they are digital pins: 11, 10, 6, 5, and 3.
preporućujemo da pinove 0 i 1 ne koristite uopće jer služe za serijsku komunikaciju s računalo i aktivirati će se prilikom svakog pokretanja ili resetiranja pločice.
Također, PWM pinovi su označeni znakom “~”. Na Croduino Basic pločicama oni su digitalni pinovi: 11,10,6,5 i 3.
