Does the Sense set include a Croduino board, or just the sensors?
Da li u dolje navedenom setu osim senzora dobijem i croduino plocu?
Originally submitted via email support on 13 August 2016. Migrated to the forum for community visibility.
The Sense set does not include a Croduino board.
Sense set ne sadrži Croduino pločicu.
Which board would you recommend for this set?
Hvala vam na odgovoru. Moze li neka preporuka ploce za ovaj set?
We recommend the Croduino Basic2. It is the simplest to get started with, and you can easily use all of these sensors with the Basic2. There are instructions on our pages showing how to do this. If you want to network your projects with the internet, we recommend the Croduino NOVA.
svakako preporučamo Croduino Basic2: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
On je najjednostavniji za početak rada, a sve ove senzore ćete bez previše muke upogniti s Basicom2. Postoje i upute na našim stranicama kako to napraviti.
Ako pak želite umrežiti projekte s internetom, preporuka je Croduino NOVA: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
