I’m building some prototypes with Arduino electronics and need help assembling an order. I have more background in programming than electronics and no experience with Arduino, so I have some additional questions.
To start, I’d like to build a standard module that takes input from any sensor and reports to a web server via WiFi module. Also, the web server should be able to communicate back to the module in both directions.
From your web shop, I’ve concluded I need the following:
BASE
I see it comes with a lot of things, but I assume it’s good for learning basic principles.
Questions:
How is the main board powered? Do I get an adapter in the package? Can it be powered via USB and is there a risk I’ll fry my computer?
Why do I need this component - isn’t Croduino compatible with Arduino shields?
PERIPHERALS
temp sensor (DHT11)
sound detector module
motion sensor (HC-SR501)
relay module (8-channel)
question: I want to control 220V but I see this is 150V?
COMMUNICATION
Bluetooth module (HC06)
WiFi - what’s the difference?
ESP8266 WiFi module
or Arduino WiFi shield?
what else do I need for 5V => 3.3V conversion?
Thank you for your help.
zelio bih raditi neke prototipove sa Arduino elektronikom pa bih molio malu pomoc kod sastavljanja narudzbe. Imam vise podloge u programiranju nego u elektronici, i nemam nikakva iskustva sa Arduinom tako da imam neka dodatna pitanja.
Za upoznavanje bi zelio sastaviti standardni modul koji kao ulaz ima bilo kakav senzor i preko WiFi modula javlja web serveru. Takoder osim sto cita da moze i obrnuto da se web server javlja modulu.
Preko vaseg web shopa zakljucio sam da mi treba sljedece:
BAZA
http://e-radionica.com/hr/croduino-set-za-pocetnike-csp-hobby.html . Vidim da tu dobivam puno vise stvari ali pretpostavljam da je dobro za upoznavanje osnovnih principa.
Pitanja:
kako se napaja glavna ploca? Dobijem li u paketu adapter? Dal moze preko USB-a i dal postoji opasnost da si spalim komp?
Zasto ova Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics komponenta, zar croduino nije kompatibilan sa Arduino shildovima?
PERIFERIJA
senzor temp http://e-radionica.com/hr/dht11-senzor-temperature-i-vlage.html
detektor zvuka Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
senzor pokreta http://e-radionica.com/hr/senzor-pokreta-hc-sr501.html
relay Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
pitanje: zelio bih upravljati sa 220V a ovo je vidim 150V?
KOMUNIKACIJA
http://e-radionica.com/hr/bluetooth-modul-hc06.html
WIFI, koja je razlika?
ili Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
sta mi jos dodatno treba za 5V => 3.3V
Hvala na pomoci.
Originally submitted via email support on 13 October 2015. Migrated to the forum for community visibility.
