I purchased a Dasduino Connect board with ESP WiFi module. I cannot find the Dasduino Connect module to download for the Arduino IDE anywhere, and I cannot find a download link for it. I also cannot connect to the board or upload code.
kupio sam dashuino connect pločicu sa ESP wifi modulom.
NE mogu nigdje naći dashuino connect module za skinuti za ardunino aplikaciju. Ni link za download tog modula. Također ne mogu dobiti konekciju sa pločom ni uploadati kod.
Originally submitted via email support on 11 September 2023. Migrated to the forum for community visibility.
You need to install the “Dasduino Board Definitions for Arduino IDE” which you can find in this repository: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub . The link to this repository is on the product page under “Arduino IDE board definition”, though I understand it could be displayed more clearly on the product page itself.
Install this board manager URL and you will then be able to download the Dasduino boards in Arduino IDE and program the Dasduino Connect.
You also need to install the CH340 drivers if you don’t already have them. They are needed for serial communication with the board: https://soldered.com/hr/learn/instalacija-ch340-drivera-croduino-basic3-nova2/
potrebno je instalirati “Dasduino Board Definitions for Arduino IDE” koji možeš naći na ovom repozitoriju: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub . Link za taj repozitorij je na toj stranici od proizvoda na “Arduino IDE board definition”, ali vidim što hoćeš reći da bi se to moglo malo jasnije prikazati na stranici samog proizvoda i prosljedio sam to timu koji radi web. Instaliraj taj dodatni board manager URL i onda ćeš moći skinuti dasduino pločice u Arduino IDE-u i programirati Dasduino Connect.
Trebaš još instalirati CH340 drivere, ako ih već nemaš. Služe za serijsku komunikaciju sa pločicom: https://soldered.com/hr/learn/instalacija-ch340-drivera-croduino-basic3-nova2/
Probaj ovo i javi rezultate ili ako imaš dodatnih pitanja.
