We use the Dasduino CONNECT PLUS (ESP32) in our organization. We’ve noticed that ESP32 by Espressif Systems has been updated to version 3.0.5, and one of the important commands for us to work with is analogWrite, which now works (we no longer need to use ledcWrite).
Is ESP32 3.0 implemented on Dasduino? (We installed the new version 1.0.1 Dasduino ESP32 Board)
Thank you in advance for your help.
U udruzi koristimo Vaš proizvod DASDUINO CONNECT PLUS (ESP32). Pratimo da je ažuriran esp32 by Espressif Systems na verziju 3.05 i jedna od nama važnih naredbi za rad sa djecom analogWrite, radi ! (ne moramo više koristiti ledcWrite).
Da li je na Dasduino implementiran esp32 3.0 ? (instalirali smo novu verziju 1.01. Dasduino Esp32 Board)
Hvala unaprijed na pomoći.
Originally submitted via email support on 14 November 2024. Migrated to the forum for community visibility.
The Dasduino CONNECTPLUS board definition is version 1.0.1 but it contains ESP32 Core 1.0.5. From what we can see in the files, this is the release our board definition is based on: Release ESP32 Arduino 1.0.5 RC2 · espressif/arduino-esp32 · GitHub
Of course, updating this would be great when we find the time.
If you want to use the latest ESP32 Arduino, you can also use that and upload via USB. The board definition within ESP32 Arduino boards is “ESP32 Dev Board” for the WROVER-E ESP32 which is on the CONNECTPLUS. I cannot guarantee 100% for this board definition because it’s not ours, but I think it should work completely OK on our board.
Dasduino CONNECTPLUS board definition je verzije 1.0.1 ali on u sebi sadržava ESP32 Core 1.0.5. koliko vidim preko fileova, ovo je release na kojem je baziran naš board definition: Release ESP32 Arduino 1.0.5 RC2 · espressif/arduino-esp32 · GitHub
Naravno, update ovoga bi bio super, čim uhvatimo vremena za to
Ako želite koristiti najnoviji ESP32 Arduino, možete koristiti i to i uploadati preko USB-a, board definition unutar ESP32 Arudino boards je “ESP32 Dev Board” za WROVER-E ESP32 koji je na CONNECTPLUSu. Ne mogu 100% jamčiti za ovaj board definition zbog toga što nije naš, ali mislim da bi trebao raditi potpuno OK na našoj pločici.
