Dasduino CONNECT PLUS mechanical specs and component dimensions for Altium
I’m working on a device using your components and need the following information:
DASUINO CONNECT PLUS with male headers:
  • Mechanical characteristics (width, length, hole coordinates, etc.)
  • Can I power the device with 5V via the VCC pin?
  • If so, do I need to disconnect the VCC power before connecting the USB cable for programming?
SIM800L:
OLED I2C 0.96" display:
easyC connector:
  • I’m designing in Altium CircuitMaker and can’t find this connector in the application. Do you know of another connector with the same dimensions that I could use?
Radim na uređaju gdje bih koristio Vaše komponente, pa Vas molim, ako je moguće da mi pošaljete sljedeće informacije:
DASDUINO CONNECTPLUS S MUŠKIM HEADERIMA
Mehaničke karakteristike (širina, dužina, koordinate rupa, …) Da li mogu uređaj napajati sa 5V preko VCC pina? Ako je moguće, da li prije programiranja uređaja (spajanja USB kabela) treba odspojiti napajanje sa VCC pina?
SIM800L
EKRAN OLED I2C 0.96“
EASYC KONEKTOR
Za dizajniranje koristim aplikaciju Altium CircuitMaker. Unutar aplikacije ne mogu pronaći ovaj element. Da li možda znate koji bi drugi element sa istim dimenzijama mogao koristiti?
Originally submitted via email support on 11 December 2022. Migrated to the forum for community visibility.
Dasduino CONNECT PLUS: yes, you can power it with 5V via the VCC pin. When the USB cable is connected, it’s best to disconnect the VCC power. SIM800L: we don’t have the exact dimensions as it’s not originally our product, but measured with calipers it should be 25mm x 24mm. OLED 0.96": mechanical dimensions are available. We’ll send you the full PN (part number) for the connector so you can find the datasheet on the internet with the mechanical dimensions.
Dasduino CONNECT PLUS: šaljem Vam u prilogu sliku mehaničkim dimenzija. Da, možete ga napajati sa 5V preko VCC pina. Kada je USB kabel spojen nabolje da odspojite napajanje s VCC pina. SIM800L - nije nažalost orginalno naš produkt pa nemamo točne dimenzije. Izmjerio sam pomičnim mjerilom te bi trebalo biti 25mm x 24mm. OLED 0.96" - šaljem Vam također sliku mehaničkih dimenzija. Poslat ću Vam puni PN(part number) tog konektora pa biste na internetu trebali pronaći datasheet gdje su mehaničke dimenzije.
Attachment omitted in migration: Screenshot_6.png
Attachment omitted in migration: Screenshot_5.png
