Dasduino CONNECTPLUS ESP32 external antenna connection
I’m using the Dasduino CONNECTPLUS (ESP32) module with ESP-NOW communication between two ESP32 boards. The signal strength is not strong enough, and I need to connect an external antenna. How can I do this and is it possible?
Originally submitted via email support on 7 October 2024. Migrated to the forum for community visibility.
Yes, this is possible. You can add an external connector for an antenna by soldering a bridge as shown in the reference material. From there, solder on an IPEX connector and use a compatible antenna (WiFi, 2.4 GHz).
For more information, see: ESP32-CAM Connect External Antenna (Extend Wi-Fi Coverage) | Random Nerd Tutorials
Can I instead destroy the resistor and short those two pins for the external antenna, since the resistor is 0.5 ohms or less? Also, where exactly should the second antenna be connected?
Attachment omitted in migration: IMG_20241008_103711.jpg
The correct approach is to do it with the resistor, as shown on the WROVER-E which also uses an external antenna. Do not remove the resistor.
