I followed your tutorial on connecting Dasduino to Arduino, but it only covers ESP8266, not ESP32, and some of the information is outdated for the current Arduino IDE. How do I connect an ESP32 Dasduino board to Arduino IDE?
Lijep pozdrav pratio sam vaš tutorial kako connectat dasduino na arduino ali ono se odnosi jedino na esp8266 a ne esp32 i plus neke stvari su zastarjele sa arduino ide. Zanima me kako da spojim esp32(vaša verzija) sa arduino ide.
Originally submitted via email support on 8 July 2024. Migrated to the forum for community visibility.
Here are the instructions for Dasduino CONNECTPLUS:
Arduino IDE Installation:
Download and install Arduino IDE from the official website: Arduino Download.
Adding Dasduino Board Definition:
- Open Arduino IDE
- Go to File > Preferences
- In the Additional Boards Manager URLs field, add the following URL: https://github.com/SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE/raw/main/package_soldered_index.json
- Click OK
Installing Dasduino Board:
- Go to Tools > Board > Boards Manager
- Type “Dasduino” in the search box
- Find “Dasduino ESP32 boards” and click Install
Selecting Dasduino ConnectPlus Board:
After installation, go to Tools > Board and select Dasduino ConnectPlus.
Selecting the Correct Port:
- Connect Dasduino ConnectPlus to your computer via USB cable
- Go to Tools > Port and select the COM port that corresponds to your Dasduino device (for example, COM3 or COM4)
Writing and Uploading Code:
- Write your own code or open an existing Arduino project
- Click the Upload button (arrow pointing right) to upload the code to Dasduino ConnectPlus
evo uputa za Dasduino CONNECTPLUS:
Instalacija Arduino IDE-a:
Preuzmite i instalirajte Arduino IDE sa službene stranice: Arduino Download. Dodavanje Dasduino Board Definition-a:
Otvorite Arduino IDE. Idite na File > Preferences. U polje Additional Boards Manager URLs dodajte sljedeći URL: https://github.com/SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE/raw/main/package_soldered_index.json Kliknite OK. Instalacija Dasduino ploče:
Idite na Tools > Board > Boards Manager. U pretraživač upišite “Dasduino”. Pronađite “Dasduino ESP32 boards” i kliknite Install. Odabir Dasduino ConnectPlus ploče:
Nakon instalacije, idite na Tools > Board i odaberite Dasduino ConnectPlus. Odabir odgovarajućeg porta:
Spojite Dasduino ConnectPlus na računalo putem USB kabela. Idite na Tools > Port i odaberite COM port koji odgovara vašem Dasduino uređaju (npr. COM3 ili COM4). Pisanje i upload koda:
Napišite svoj kod ili otvorite postojeći Arduino projekt. Kliknite na gumb Upload (strelica prema desno) kako biste uploadali kod na Dasduino ConnectPlus.
Nadam se da ovo pomaže, javi ako nešto ne bude radilo, ovdje smo da pomognemo.
Which pins on the ESP32 have the SDA and SCL ports?
Hvala puno.
A na kojem pinu na esp32 se nalaze scd sda portovi.
According to the product pinout (https://soldered.com/productdata/2022/06/Dasduino-CONNECTPLUS.png): SDA is pin 21, SCL is pin 22. Alternatively, you can use easyC (I2C via the small easyC cable, which is equivalent to pins 21 and 22, VCC and GND).
evo pinouta koji se nalazi na stranici od proizvoda: https://soldered.com/productdata/2022/06/Dasduino-CONNECTPLUS.png
SDA je pin 21, SCL je pin 22, ili možeš koristiit easyC (to je I2C preko tog malog easyC kablića, ekvivalentno je pinovima 21 i 22, VCC i GND).
