I bought a Dasduino ConnectPlus and tried to compile code, but it fails to compile. I need help.
Poštovani, kupio sam kod vas Dasduino ConnectPlus, pokušao sam kompilirati kod koji vam šaljem u dodatku, ali ne prolazi. Molio bih pomoć. Hvala
Attachment omitted in migration: VIRTUALNI PIN-POGRJEŠKA.docx
Originally submitted via email support on 26 February 2024. Migrated to the forum for community visibility.
The issue is that the led_pwm function is not defined for the board you’re using. For board definitions we use the Dasduino ConnectPlus board definition which you can install via this link: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub - the tutorial is at the bottom in the README.
Try using that board instead of the generic ESP32 WROVER module. The led_pwm function may then be defined, but we cannot guarantee it. We cannot provide user support for third-party software, but we can offer a few suggestions.
If it doesn’t work with the Dasduino board definition, you could try the ‘ESP32 Dev Module’ board definition.
Problem je u tome što funkcija led_pwm nije definirana za ploču koju koristiš. Mi za board definition koristimo baš Dasduino ConnectPlus board definition koji možeš instalirati putem ovog linka: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub - tutorial je na dnu u READMEju.
Probaj koristiti taj board a ne generički ESP32 WROVER module. Možda će ta funkcija led_pwm onda biti definirana, ali ne možemo garantirati. Mi ne možemo pružiti korisničku podršku za softver pisan od treće strane, možemo samo dati nekoliko prijedloga
Ako ne radi sa Dasduino board defom, možda probaj ‘ESP32 Dev Module’ board definition.
