Dasduino CORE I2C SDA and SCL pins
Which pins can be used as SDA and SCL?
Zanima me koji pinovi se mogu koristit kao SDA i SCL Hvala.
Originally submitted via email support on 5 January 2023. Migrated to the forum for community visibility.
Pin A4 is SDA while pin A5 is SCL.
I’m sending you a pinout diagram where you can see the other pins as well. Note that if you use SPI communication, the CLK pin is actually pin D13 and not D8 as shown in the diagram.
pin A4 je SDA dok je pin A5 SCL.
Šaljem vam u prilogu pinout gdje možete vidjeti i ostale pinove. Šaljem napomenu da ukoliko budete koristili SPI komunikaciju da je CLK pin zapravo pin D13 a ne D8 kako je na slici.
Attachment omitted in migration: Dasduino CORE Pinout.jpg
