I connected my Dasduino CORE to 4 AA batteries for a total of 6V. I see the product page states it works at 5V, but I wanted to ask if everything will be okay if I leave it like this?
Pozdrav spojio sam vas dasduino core na 4 AA baterije od sveukupno 6V.Vidim da na stranici pise da radi na 5V ali sam vas htio pitati hoce li sve biti uredu ako ostavim ovako?Unaprijed hvala.
Originally submitted via email support on 21 November 2023. Migrated to the forum for community visibility.
The microcontroller on which the Dasduino CORE is based accepts voltages up to 5.5V, so this could damage the device. I recommend connecting the batteries so you have exactly 5V at the output, or use our Li-Ion battery on the JST connector on the board, which should work reliably.
Mikroupravljač na kojem je Dasduino CORE zasnovan prihvaća napone do 5.5V pa bi to moglo oštetiti uređaj. Preporučujem da spojiš baterije tako da imaš točno 5V na izlazu ili da koristiš našu Li-Ion bateriju na JST konektoru na ploči, to bi trebalo pouzdano raditi.
