I purchased an ATmega328 board from you and now I cannot upload a program to it. I’m working in Microchip Studio. I’m wondering if it’s enough to just connect USB to the computer or if I need a programmer and bootloader.
Kupio sam kod vas plocicu ATmega 328
I sad nemogu prebacit program na nju
Radim u microchip studio programu
Pa me zanima dali je dovoljno samo ukljucit usb u kompjuter ili trebam programator i boatloder
Originally submitted via email support on 28 August 2025. Migrated to the forum for community visibility.
Which product exactly did you purchase? If you got the Dasduino CORE (Browse All Categories | Soldered), it has a bootloader built in and can be programmed from Arduino IDE.
If you only have an ATmega328P chip (https://soldered.com/product/atmega328p-smd-microcontroller/), this chip requires a bootloader and additional hardware for programming. See this tutorial: https://www.electronics-lab.com/project/programming-atmega328p-microcontroller-with-arduino-ide/
hvala na upitu! Možeš li mi reći točno koji proizvod si kupio, jesi li uzeo naš Dasduino CORE? Browse All Categories | Soldered
On na sebi ima bootloader i može se programirati iz Arduino IDE-a.
Ili samo ATmega328p chip? https://soldered.com/product/atmega328p-smd-microcontroller/
Ovaj chip treba bootloader i dodatni hardver za programiranje, vidi ovaj tutorial: https://www.electronics-lab.com/project/programming-atmega328p-microcontroller-with-arduino-ide/
