Dasduino Core VCC connector power input options
Can the VCC connector on Dasduino Core be used as a 5V power input for the board, or is it an output?
VCC konektori na dasduino core i općenito mogu koristit kao napajanje 5V za pločicu ili je to (OUTPUT) 5V?
Originally submitted via email support on 19 July 2023. Migrated to the forum for community visibility.
The VCC connector can be used to supply 5V power. While powering the device via USB is preferable as it has a dedicated circuit path for power delivery, the VCC pin will work fine as well.
Note that there is also a battery connector and BAT pin which accepts approximately 3.8 to 4.2V max (representing a full battery charge) and can also power the board effectively.
VCC konektori se mogu koristiti za spajanje napajanja od 5V. Najbolje je napajati uređaj s USB-a jer to predstavlja odvojeni dio strujnog kruga koji je baš za napajanje no VCC pin će isto raditi sasvim OK.
Htio bi samo napomenuti da postoji i konektor za bateriju i BAT pin koji prima ~3.8 do 4.2V max (što predstavlja punu bateriju) koji isto dobro može napajati pločicu.
