Does a Dasduino board exist with two serial ports? I’m trying to connect device A which sends data on a serial port - a Dasduino/Arduino should receive that data and send only a portion of it to a second serial port connected to device B. Do you know if there’s a better solution for this?
da li postoji Dasduino pločica sa dva serial porta ?
Što pokušavam napraviti ? Imam uređaj A koji šalje podatke na serial port, dasduino/arduino treba prihvatiti te podatke i samo djelič podatkak poslati na drugi serial port tj na uređaj b. Možda znate da postoji neko bolje riješenje.
HVALA
LP [name removed],
Originally submitted via email support on 31 October 2023. Migrated to the forum for community visibility.
You can do this with the board you already have. You can use SoftwareSerial - it sends the same messages as Serial, but the processor handles everything ‘manually’ and can work on almost any pins. See: https://docs.arduino.cc/learn/built-in-libraries/software-serial
It’s a good enough solution in terms of speed and reliability if you only need to send simple data occasionally, as you want to send to device B. The advantage is it gives you flexibility with pin selection.
Mislim da možeš ovo raditi sa pločicom koju već imaš, možeš koristiti software serial - to u principu šalje iste poruke kao Serial samo što ti procesor sve obavlja ‘ručno’ i može raditi na skoro bilo kojim pinovima. Pogledaj ovo: https://docs.arduino.cc/learn/built-in-libraries/software-serial
U biti to je dovoljno dobro rješenje što se tiče brzine i pouzdanosti ako samo povremeno moraš poslati neki jednostavni podatak, kao što ti želiš slati na uređaj B. Prednost je što dopušta fleksibilnost oko pinova.
Which pins on the Dasduino should I connect RS232 to? If I understood correctly, I can use any GPIO pin - the labels on the board like PA2, PA1, etc. - how do I define them in code for SoftwareSerial.h? SoftwareSerial RS232Serial(16, 17); - which pins/numbers do I need to put here?
na koje pinove na Dasduino bi trebao spojiti RS232 ??
ako sam dobro shvatio mogu na bilo koji GPIO pin
ove oznake na samom bordu PA2,PA1 itd….. kako njih definiram u kod za SoftwareSerial.h SoftwareSerial RS232Serial(16, 17); <<< koje pinove/brojeve trebam ovdje staviti HVALA LP [name removed],
I checked - if you use the literal pin name within Arduino, it should work. Here’s how the #define values look for this Dasduino:
So if you want software serial on PA3 and PA4 for example, it would be:
SoftwareSerial RS232Serial(PA3, PA4);
It should work - let me know the results and we can troubleshoot if needed.
provjerio sam, ako koristiš doslovno ime pina unutar Arduina, trebalo bi prolaziti, evo kako izgledaju #define-ovi za taj Dasduino:
Dakle, ako želiš software serial na PA3 i PA4 npr. onda bi to bilo
Trebalo bi raditi, javi rezultate pa ćemo vidjeti.
