E-radionica Inkplate 6 not supported
I use an old Inkplate6 from e-radionica but it is not working with the soldered library. If I select the board “Soldered Inkplate 6” I can upload the code successfully but the Inkplate is not booting. If I select the Board “e-radionica.com Inkplate6” there is an error: "…/driverSelect.h:54:2: error: #error “Board not selected!” , see Screenshot. It seems, this type of board is not implemented in this file.
I’m using InkplateLibrary 11.2.0 and Inkplate Board 8.1.0
Hello @hoffi89,
The issue you are facing is due to us updating the board definition and placing it in a newer package. Please download the newer one following the steps as described here: Inkplate 6 - Quick start guide | Soldered Documentation
Best regards,
JosipKuci
ah, there was “Inkplate Boards” by Soldered and now it’s “Soldered Inkplate Boards” by Soldered Electronics :smiley: Thanks, now it is working!
