ESP32-S3 + SPK0641HT4H microphone compatibility for prototyping
I am developing a V1 hardware prototype based on an ESP32 microcontroller with a MEMS I2S microphone. My aim is to avoid hand-soldering sensitive components and instead use fully assembled, tested boards from a single supplier where possible.
I would like to ask:
• Do you currently supply an ESP32 development board suitable for prototyping?
• Do you supply a fully soldered MEMS microphone breakout (I2S, 3.3 V)?
• Have these components been tested together, or can you recommend a compatible pairing?
• Can both boards be connected and used without custom soldering (headers, jumper wires, etc.)?
For now, I am looking to purchase 1–2 units for V1 testing. If the V1 prototype is successful, I would then like to explore the possibility of small-batch manufacturing (approximately 25-50 units) with a single supplier.
I would appreciate your advice on what you currently offer and what you would recommend for this approach.
Thank you for your time.
Kind regards,
Adam SMITH
Razvijam V1 hardverski prototip temeljen na ESP32 mikrokontroleru s MEMS I2S mikrofonom.
Cilj mi je izbjeći ručno lemljenje osjetljivih komponenti te, ako je moguće, koristiti potpuno sastavljene i testirane pločice od jednog dobavljača.
Zanima me sljedeće:
• Nudite li trenutno ESP32 razvojnu pločicu pogodnu za prototipiranje?
• Nudite li potpuno zalemljenu MEMS mikrofon pločicu (I2S, 3.3 V)?
• Jesu li ove komponente testirane zajedno, ili možete preporučiti kompatibilnu kombinaciju?
• Mogu li se obje pločice koristiti bez dodatnog lemljenja (pinovi, jumper žice, breadboard itd.)?
U ovoj fazi tražim 1–2 komada za V1 testiranje.
Ako V1 prototip bude uspješan, u sljedećem koraku bih želio razmotriti malu serijsku proizvodnju (otprilike 25-50 komada) s jednim dobavljačem.
Bio bih zahvalan na vašem savjetu o tome što trenutno nudite i što biste preporučili za ovakav pristup.
Hvala unaprijed.
Originally submitted via email support on 8 January 2026. Migrated to the forum for community visibility.
We have an ESP32-S3 board. The header pins need to be soldered (headers are included). We have a MEMS Microphone SPK0641HT4H Breakout, which has been tested with the ESP32-S3 board and confirmed to work flawlessly. However, you do need to solder the header pins on it as well. Both boards can be connected over a breadboard using jumper wires via the header pins.
