Fire Sensor Board 333047 operating temperature range
I’m evaluating the Fire Sensor Board 333047 for a product that requires infrared flame detection. The application has a strict operating temperature requirement of -40°C to 155°C. Is this sensor rated for this temperature range? If not, are there alternatives with the same infrared flame detection capabilities?
Originally submitted via email support on 10 July 2024. Migrated to the forum for community visibility.
The 333047 is not rated to be accurate or functional in that temperature range. The onboard chip is a LM393 comparator, which are typically rated to work up to 80°C maximum. 155°C is beyond the operating range.
For your application, you would need to look into industrial or military grade IR sensors. Alternatively, you can use the 333047 design as a basis and source components rated for extreme temperature operation. The design is straightforward—it’s an application circuit for the comparator chip.
The hardware design is available here: GitHub - SolderedElectronics/Simple-fire-sensor-board-hardware-design: Hardware design, BOM, gerbers and 3D files for Simple-fire-sensor-board designed by Soldered Electronics. · GitHub
