I purchased a Hall effect sensor breakout with digital output and connected it with a 30K pull-up resistor and 5 volt power. I placed a magnet on a 3" diameter disc attached to a DC motor running at about 30 RPM, producing a pulse approximately every 1/2 second. On an oscilloscope, the output pulled low as the magnet passed the sensor for about 400mS as expected. However, detection is inconsistent: sometimes the sensor fails to detect the magnet, sometimes the low pulse is only about 200mS. The pattern is random - the sensor might detect 10 times, skip one, detect 16 times, skip one, or skip several detections before detecting once or twice. Moving the magnet distance from 4mm to 20mm made no difference. At 25mm the sensor almost never detects, but I plan to operate at 4-6mm. Wire runs are only about 1" long. I’m working on an ESD mat with a grounded wrist strap. Why is detection random?
Originally submitted via email support on 7 February 2026. Migrated to the forum for community visibility.
