HC-SR501 motion sensor triggering LED erratically on Croduino
I connected the HC-SR501 motion sensor to a Croduino and it’s not reading motion correctly. The sensor should turn on an LED when it detects motion, but the LED keeps turning on and off by itself. Could the problem be that the USB voltage from the laptop/computer is too low, or is something else wrong?
Spojila sam senzor pokreta HC-SR501 na Croduino i neće da pravilno očitava pokrete. Senzor bi prilikom očitanja signala trebao paliti LEDicu, međutim LEDica se pali i gasi sama od sebe. Dali bi problem mogao biti u tome što je napon USBa s laptopa/računala malen ili je u nečemu drugome stvar?
Originally submitted via email support on 28 April 2016. Migrated to the forum for community visibility.
The HC-SR501 sensor has two potentiometers on it for adjusting sensitivity and the distance at which the sensor responds. Try adjusting them to calibrate the sensor for your specific use case.
senzor HC-SR501 na sebi ima dva potenciometra za podešavanje osjetljivosti i udaljenost na koje senzor reagira. Probajte se poigrati s njima kako bi podesili senzor za Vašu upotrebu.
https://e-radionica.com/hr/blog/2015/08/19/kkm-hc-sr501/
