Hot desoldering plate 946C temperature calibration
I have a Hot desoldering plate 946C. It’s off by about 25 degrees. Is there a menu guide or a way to calibrate it?
Originally submitted via email support on 21 November 2025. Migrated to the forum for community visibility.
To calibrate the Hot Plate, you will need to open it to access the mainboard. On it you will find a potentiometer (small blue cube with a cross inside). Using a small screwdriver, unscrew the potentiometer until the temperature is correct. Make only very small turns (a couple degrees) at a time to see how the temperature changes.
You can also check out this guide: https://www.youtube.com/watch?v=Gv2sRJ9y_Ok
