HX711 ADC with load-cell module for weight measurement on Arduino
Do you have a component that measures weight (mass) in grams and transmits that value to an Arduino? If such a component exists in your offer, could you provide information on how to obtain it?
molim Vas informaciju imate li komponetnu koja mjeri težinu (masu) u gramima i tu vrijednost prenosi na arduino. Ukoliko nemate takve komponenete molim Vas informaciju kako da to pribavim. Lp [name removed] Šipek
Originally submitted via email support on 1 February 2017. Migrated to the forum for community visibility.
We have a load-cell module. These modules produce extremely small voltages, so you need a very precise ADC. We recommend the HX711 24-bit ADC, which is specially designed for load-cell modules.
Imamo load-cell modul: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
Ovi moduli daju izuzetno male napone tak da Vam treba vrlo precizan ADC. Preporučujemo : Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics
On je specijalno napravljen za loadcell module.
I like what you’ve offered. Is it possible for those two components to be connected together so I get a functional scale that I can simply connect to a microcontroller? Also, would you be able to create this and what would it cost?
Pitanje: Da li je moguće da mi se ta dva elementa spoje pa da dobijem funkcionalnu vagu koju mogu samo spojiti na mikrokontroler. Koja bi bila cijena toga da to izradite? Oprostite na neukim pitanjima,ali ja sam [name removed] u školi koji tek poćinje učiti o mikrokontrolerima zajdno s klicmia. Hvala još jednom na pomoći.
For educational purposes we would be happy to donate our time. We would need to make a small breakout for the HX711 (ADC). We can provide code along with it. Do you need R1? Could you please send us information about your school? You can also see the datasheet here: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics Or, it will probably be simpler for you if you briefly explain to us what you intend to use the scale for so we can adapt it as best as possible.
ako se za edukacijske svrhe rado ćemo “donirati” svoje vrijeme. Morali bi samo mali breakout odraditi za HX711 (ADC). Šaljemo i kod uz to. Trebate li R1? Molimo da nam pošaljete podatke škole. Također, datasheet možete vidjeti ovdje: Soldered: Open-Source Electronics, Boards, Sensors & Modules – Soldered Electronics Ili, vjerovatno će Vam biti jednostavnije, samo nam kratko objasnite za što biste koristi vagu kako bi ju što bolje prilagodili.
Attachment omitted in migration: Ponuda KUPCI-GRAĐANI_42_2017.pdf
