HX711 Load-cell Amplifier
Is there a way to enable 80 Hz readout on this board?
Hello Maciek,
On ver 1.2 of the PCB (you can find the version listed on the bottom left corner of the PCB, it should say v1.2.) there is a jumper labeled JP1 with three pads. By default, the , middle pad is connected to the left pad (GND), which places the sensor in a 10Hz rate. To place it into 80Hz mode, use a razor or scalpel to cut the trace between the middle and leftmost pad and then solder the middle pad to the rightmost pad.
On versions 1.0 and 1.1 the sensor is only available in 10Hz mode.
