INA219 current measurement 10-100 mA range and precision settings
I previously purchased a dasduino and other components from you, including an ACS712. Since that’s no longer available, can you help me choose components to measure current in the 10-100 mA range with moderate precision (around 5 mA would be acceptable)? I’m assuming I need an INA219 and possibly an additional resistor. I’d prefer the KKM (https://soldered.com/hr/learn/kkm-digitalni-ampermetear-voltmetar-ina219/) but it has a built-in shunt of 0.1Ohm which I don’t think suits my needs, and I’m not sure if I can replace it. Other solutions would also work, so feel free to suggest alternatives.
Lani sam od vas kupio dasduino i još neke elemente, između ostalo i ACS712. Kako on više nije dostupan, možete li mi samo pomoći u izboru elemenata koji bi mi trebali kako bih mjerio struju u rasponu od 10-100 mA, sa nekom neprevelikom preciznošću (recimo bar 5mA). Pretpostavljam da mi treba INA219 i neki dodatni otpornik (ili više njih). Zapravo bih najrađe uzeo KKM (https://soldered.com/hr/learn/kkm-digitalni-ampermetear-voltmetar-ina219/) ali on već ima ugrađeni shunt od 0,1Ohm koji mi pretpostavljam ne odgovara a ne znam mogu li ga zamjeniti.
Odgovarale bi mi i bilo koje druge solucije pa slobodno predložite. Ja bih onda napravio narudžbu.
Hvala i srdačan pozdrav,
Originally submitted via email support on 2 February 2024. Migrated to the forum for community visibility.
The INA219 breakout has a built-in shunt resistor of 0.1 Ohm. With this resistor you can measure currents up to ±3.2A. If you change the gain settings in the IC itself, you can configure it to measure a maximum of ±400mA with 0.1mA precision. For your application, this product would be suitable.
INA219 breakout ima ugrađeni shunt otpornik od 0.1 Ohm. S navedenim otpornikom možete mjeriti struje do ±3.2A. Ako promijenite postavke pojačala u samom ICu možete dobiti da mjeri maksimalno ±400mA uz preciznost od 0.1mA. Prema vašem upitu ovaj proizvod bi odgovarao za vašu primjenu.
Thank you for the information. I should clarify that I meant to link to this product: Ručni alati | Osnovni alati za elektronički radni stol – Soldered Electronics. The reason is that I need something enclosed and protected since I need to carry it to various locations and leave it for several days. I want to measure power consumption continuously during this time, store the data, and analyze it afterwards. It would also be useful to monitor consumption in real-time. If I understand correctly, the ±400mA range and 0.1mA precision are more than sufficient for my needs. Can I change this configuration in code without needing an additional external resistor (I see the product has a connector for external resistors)?
Hvala na informacijama. Kao prvo se ispričavam što sam stavio krivi link na proizvod. Naime mislio sam uzeti ovo: Ručni alati | Osnovni alati za elektronički radni stol – Soldered Electronics. Razlog je taj što bi mi dobro došlo da imam nešto “zatvoreno/zaštićeno/okliopljeno” jer to moram nositi na više različitih mjesta i ostaviti na nekoliko dana (želim cijelo to vrijeme mjeriti trošenje struje, te podatke pohraniti i nakon toga analizirati. Također je dobro da mogu stalno gledati koliko troši pa mi navedeno izgleda super.
Meni je više nego dovoljan 400mA range i 0.1mA preciznost. Ako sam dobro shvatio, tu postavku mogu promjeniti u kodu i ne treba mi dodatni vanjski otrponik (vidim da proizvod ima kablić za spajanje vanjskih otpornika)?
Ako je to sve tako, ja bih to odmah naručio, zajedno sa još nekiim stvarima koje mi trebaju.
The digital voltmeter-ammeter display only shows current and voltage on its screen and has no capability to store data via a microcontroller. The INA219 can have different gain settings that determine your measurement range and precision. All of this is configured in code.
Navedeni digitalni voltmetar-ampermetar samo prikazuje struju i napon na zaslonu, a nema mogućnost pohrane iste putem nekog mikrokontrolera.
INA219 može imati različito pojačanje te time određujete opseg mjerenja i preciznost. To se sve postavlja u kodu.
