Your example doesn’t specify which library to use. I tried IRemote but it doesn’t work. The same example in the original source also doesn’t work. Has anyone on your technical team tested this example? If so, which library did you use? I’m attaching an error log that shows the library isn’t being recognized. I removed RobotIRemote from Arduino IDE 1.0.6.
U vasem primjeru niste naveli library. Ja sam upotrebio IRemote, ali
ne funkcionira. Isti takav primer u originalu takodjer ne funkcionira.
Dali je netko od vasih strucnih suradnika isprobao taj primjer, ako
jest koji library. Prilazem ispis pogresaka iz koji je vidno da ne
prepoznaje librarary. Iz IDE 1.0.6 maknuo sam RobotIRemote.
Attachment omitted in migration: KMMerror.txt
Originally submitted via email support on 17 September 2017. Migrated to the forum for community visibility.
