Inkplate 10 battery installation and compatibility
Does the Inkplate 10 come with its own battery? If not, can you provide information on what battery to use and how to install it?
Originally submitted via email support on 29 March 2022. Migrated to the forum for community visibility.
The Inkplate does not come with a battery due to shipping restrictions on lithium batteries. If you want to use Inkplate with a battery, you can buy a Li-Ion battery with a capacity of 1200mAh or higher. The Inkplate has a JST battery connector - you only need to connect the battery to it. Be careful to check the polarity of the battery before connecting it to Inkplate, as some batteries can have opposite polarity and will not work with Inkplate if reversed.
