Inkplate 10 battery runtime with 1200mAh capacity
I’m interested in Inkplate 10 with case and battery. How long can the battery run the device?
Originally submitted via email support on 3 May 2023. Migrated to the forum for community visibility.
Battery runtime depends on your programming and use case. For example, if you use Inkplate to download pictures from the web every hour and show them, a battery of 1200mAh can last about 16 days. This depends on the image size, internet speed, and other parameters - the exact runtime will vary based on your specific application.
