I received an Inkplate 10 and started loading demo applications from the InkplateLibrary using Arduino. I can load many examples fine, but any demo using WiFi causes a CORRUPT HEAP message on the USB serial line followed by device reboot. I tried both demos where the Inkplate 10 connects to a WiFi AP and a demo where it hosts a WiFi AP—both result in the same issue.
With the Hourly_Weather_Station_Example, I get:
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:1100 load: ,len:10900 load: ,len:6360 entry 0x400806b4 [esp32-hal-psram.c:47] psramInit(): PSRAM enabled CORRUPT HEAP: multi_heap.c:432 detected at 0x3ffd1dfc abort() was called at PC 0x4008f5eb on core 1
ELF file SHA256:
Backtrace: 0x4008b290:0x3ffcd830 0x4008b50d:0x3ffcd850 0x4008f5eb:0x3ffcd870 0x4008fbb0:0x3ffcd890 :0x3ffcd8b0 0x400875a6:0x3ffcd8d0 :0x3ffcd8f0 0x4000beaf:0x3ffcd910 0x4008c56a:0x3ffcd930 0x400e3550:0x3ffcd950 0x400d5a0f:0x3ffcd980 0x400d6020:0x3ffcd9b0 0x400d6211:0x3ffcdab0 0x400d635b:0x3ffcdad0 0x400d2b29:0x3ffcdb70 0x400dce0e:0x3ffcdbc0 0x4008bdd6:0x3ffcdbe0
Rebooting...
I connected the Inkplate 10 to a USB-C 5V 3A wall charger and the issue persists. There is no battery attached. Could this be bad hardware? Is there anything else I can do to debug this? I need WiFi for my main use case.
Originally submitted via email support on 27 April 2022. Migrated to the forum for community visibility.
