Inkplate 10 compatibility with higher-capacity 4000-6000mAh batteries
I’m interested in an Inkplate 10 and would like to use a larger battery than the standard option. I have two questions about the 4000-6000mAh batteries:
  1. Are they compatible with the Inkplate 10 in general? Is the 3000mAh battery the same one shipped with the battery option?
  2. Will the 4000-6000mAh batteries fit inside the Inkplate 10 enclosure?
Originally submitted via email support on 29 January 2024. Migrated to the forum for community visibility.
Yes, those batteries will work well with Inkplate. The JST connector is compatible.
They won’t fit the enclosure as-is. However, you can modify the enclosure’s STL file to expand the battery holder or remove it entirely. The enclosure files are available to help you customize it for a larger battery.
Attachment omitted in migration: inkplate10_3d_files2.zip
