Inkplate 10 display non-responsive after upload
I’ve tried all the examples in the Arduino IDE to get the Inkplate 10 to function but the display doesn’t respond. The code compiles and uploads successfully, and I can communicate over the serial port, but the display itself never changes.
I ran code with:
display.clearDisplay();
display.display(true);
But I don’t see any flickering on the display.
The basic hello world example output:
rst:Testing Inkplate…
Wavefrom load failed! Upload new waveform
I tried the waveform upload example, but the screen never showed the different shades. I can’t find any similar issues online and I’m not sure how to troubleshoot further.
Originally submitted via email support on 9 October 2025. Migrated to the forum for community visibility.
Try switching your board definition. If you’re using e-Radionica Inkplate 10, switch to Soldered Inkplate 10, and vice versa.
I’ve seen the documentation refer to a distinction between “e-Radionica Inkplate 10” and “Soldered Inkplate 10”, but that’s not what I’m seeing in the Arduino library board options. Neither option refers to “e-Radionica” or “Soldered” in the title. I installed the “Inkplate Boards” package following the documentation, so I can’t follow your suggestion without more specific instructions.
Follow these instructions to add the correct .json file so you can install the right board definitions. The Inkplate boards package 1.0.1 that’s appearing is outdated - the latest version is Inkplate boards 8.1.0.
The older board definitions would be labeled “e-Radionica” (our old company name), while the current ones are “Soldered”. Following the README in those instructions should let you install the correct Inkplate boards and get started.
