Inkplate 10 display not updating after flashing
I’ve tried both my own scripts and the sample library examples, but the Inkplate 10 display won’t update. After flashing, it still shows the startup screen from delivery. What’s wrong?
Originally submitted via email support on 27 March 2023. Migrated to the forum for community visibility.
Did you install the newest board definition and the newest library? There are 2 Inkplates board definitions - if you have the newer Inkplate, you need to select “Soldered Inkplate10”.
I was able to flash the waveform_eeprom-programming example. But how can I change or burn the selected version without a touchpanel on the Inkplate 10?
Did you manage to run an example to print something on the screen? Do the other examples work properly for you? By the way, Inkplate 10 has factory burned waveform, so you don’t need to change it.
