What is the maximun size for the battery in the Inkplate 10 enclosure? Will the 10000mAh battery be a fit ?
Hi @eiswind , the Inkplate 10 enclosure has a slot for our 3000mAh battery as well as our 1200mAh battery. You could potentially modify the .stl’s to fit a single 10000mAh but watch out for the thickness!
