Inkplate 10 enclosure maximum battery capacity
What is the maximum battery size that will fit in the Inkplate 10 enclosure? I see the option with battery included comes with a 1200 mAh battery. What battery with the most capacity will fit in the housing?
Originally submitted via email support on 21 August 2025. Migrated to the forum for community visibility.
The enclosure has a spot for a 3000 mAh battery. It goes in the upper slot.
Is this the maximum size, or would a bigger battery also fit in the enclosure?
The 3000 mAh is the maximum size supported by our enclosure. You could modify the .stl to your needs and fit any of our other batteries. Their dimensions are documented at Li-Ion Battery - Hardware details | Soldered Documentation
The .stl files for the enclosure are available at Soldered-Inkplate-10-hardware-design/OUTPUTS/V1.3.1/3D printable files at main · SolderedElectronics/Soldered-Inkplate-10-hardware-design · GitHub
