Inkplate 10 Google Calendar example compilation errors
I keep getting errors while trying to compile the example. It looks like it’s missing some libraries or they’re not loading properly.
Originally submitted via email support on 4 January 2024. Migrated to the forum for community visibility.
The errors from compiling the example appear because you saved a copy of the example into a different working directory. Arduino won’t copy over other external files the example uses. In your Arduino libraries folder, please go and find the Google Calendar example folder: Inkplate-Arduino-library/examples/Inkplate10/Projects/Inkplate10_Google_Calendar at master · SolderedElectronics/Inkplate-Arduino-library · GitHub
From this folder, copy over all files except the .ino sketch into your working directory where you saved your example. If you need to find that folder, you can do so in Arduino in Sketch->Show Sketch Folder
