Inkplate 10 PCB model doesn't fit case, missing 3D component models
I want to edit the case to expose the SD card, but the Inkplate 10 PCB model does not fit into the case model. Can you update the GitHub repo with the correct PCB model? Also if you can include the PCB standoffs that would be great!
Attachment omitted in migration: Screenshot 2025-02-05 at 2.08.28 PM.png
Originally submitted via email support on 5 February 2025. Migrated to the forum for community visibility.
The .stl for the case is for the Soldered Inkplate. The older e-radionica Inkplate model files are here:
The standoffs are 10mm, hexagonal M3 screw standoffs (3mm hole).
The 3D models for the components are missing - where can I find those?
In the same repository, in OUTPUTS, there is a .step file for Inkplate itself. It does contain the components.
