I’ve been using an Inkplate 10 for 5 years but the screen has stopped working due to an impact. The board itself is fine, it’s just the screen. Is there any way to get the screen replaced? If so, what e-ink screen should I get?
Originally submitted via email support on 9 January 2026. Migrated to the forum for community visibility.
Screens are not sold separately by Soldered, but they are easily obtainable on AliExpress and similar sites. The Inkplate 10 used different panels at different times, so any compatible panel you find will work. Keep in mind that you will need to set a different waveform if you use a different panel than the original, but this can be configured once your replacement panel arrives.
You can check the ribbon cable of your specific panel and try to find a replacement - the panel name always starts with ED…
Note that Soldered is not liable for any issues arising from ordering from third-party sources.
