Inkplate 10 screen not responding to power button
I connected the device and changed the baud rate, but I could not find the serial monitor. The screen won’t respond when I click on the power button, though the device is recognized by the computer.
Originally submitted via the contact form on soldered.com on 5 July 2022. Migrated to the forum for community visibility.
Can you power the Inkplate and record a video of what happens? Does the Inkplate refresh the screen?
Adding the video.
Attachment omitted in migration: WhatsApp Video 2022-07-06 at 21.54.38.mp4
Please try to use Arduino IDE and open the Serial monitor. You can also upload new code to the Inkplate to see what happened.
Because the display doesn’t update, you can try to clean the display connector. On the back side you can find a flat cable that is connected to the connector.
I tried connecting the Inkplate but it won’t respond. Adding a video.
Attachment omitted in migration: inkplate.mp4
First, you need to download the core for your Inkplate from this link: GitHub - SolderedElectronics/Dasduino-Board-Definitions-for-Arduino-IDE · GitHub
After that, select Inkplate and the port in Arduino IDE as shown in the pictures. Then try to upload any Inkplate example. You can download Inkplate examples from this link: GitHub - SolderedElectronics/Inkplate-Arduino-library: Inkplate family Arduino library. The easiest way to add e-paper to your project. · GitHub
