I have an Inkplate 10 with enclosure. According to the product description, the enclosure should permit the use of all three capacitive touch pads, but I’m experiencing two issues.
First, the SD card is not detected. I’ve tried with 32 GB and 64 GB Sandisk Ultra SD cards, formatted as FAT32 with both GPT and DOS partition tables. I’ve tested with both Arduino and ESP-IDF via PlatformIO.
When uploading epub-inkplate, I get:
E (1920) vfs_fat_sdmmc: sdmmc_card_init failed (0x108).
assertion “xQueue” failed: file “/home/user/.platformio/packages/framework-espidf/components/freertos/queue.c”, line 1946, function: uxQueueMessagesWaiting
abort() was called at PC 0x401f26d4 on core 0
When uploading Inkplate_SD_TXT_File, I get:
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
Other Arduino examples (BW, Grey, partial updates, low power) work fine. The only programs that fail are those involving the SD card.
Second, the capacitive touch pads are not usable with the enclosure, which contradicts the product description. I’ve seen advice to add aluminium foil to make it work, but the enclosure should work as advertised.
Originally submitted via email support on 22 October 2021. Migrated to the forum for community visibility.
