I recently purchased an Inkplate 10 and tried to install a battery. When I connected a 3.7V LiPo (3700mAh) battery via the JST connector, I noticed several issues:
- The board no longer woke on hitting the power switch (with battery alone or with USB and battery)
- The 5-pin IC near the CHRG LED became very hot to the touch
- There was a slight electronic smell
Removing the battery reverted the board to normal behaviour. The battery was connected via JST connector so I don’t believe it was cross-wired. I’m wondering if the issue is that the battery is completely flat and the board is working overtime to charge it at 500mA. Should I be concerned by the temperature of the IC near CHRG?
Originally submitted via email support on 1 November 2021. Migrated to the forum for community visibility.
