My Inkplate 10 won’t run the example programs that contain WiFi. The only modification I made to the examples is to add my WiFi info. I’ve tried programming it from two different computers with the same result. It boots up then crashes, then cycles between booting and crashing.
Serial output:
rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load: ,len:10900
load: ,len:6360
entry 0x400806b4
CORRUPT HEAP: multi_heap.c:432 detected at 0x3ffd1e6c
abort() was called at PC 0x4008f517 on core 1
Originally submitted via email support on 19 July 2022. Migrated to the forum for community visibility.
