I recently received an Inkplate 2 and would like to add a battery to it. Does the current case have enough room for a battery, or will I need to print a new one?
Originally submitted via email support on 5 May 2024. Migrated to the forum for community visibility.
The Inkplate 2 case is the same in the version with or without battery. The batteries on Inkplate 2 are soldered to the PCB on + and - terminals and they are not connected to a JST connector, so you’ll have to do that in a safe way if you want to attach a battery.
You can check the dimensions of the Li-ion battery (600mAh, 3.7V) to see what you can fit in the case.
