How do I remove the 4 cylinders on the back of the Inkplate 2? Can I use a soldering iron?
Originally submitted via email support on 2 April 2025. Migrated to the forum for community visibility.
Yes, the 4 cylinders on the back of the Inkplate 2 can be removed using a soldering iron. However, please proceed with extreme care, as it’s easy to damage the screen during this process.
Here are some tips:
Here’s an additional tip regarding the removal of the 4 cylinders (standoffs) on the back of the Inkplate 2.
If you don’t have a larger soldering iron tip available, you can also use a smaller tip — just insert it directly into the cylinder (standoff) and hold it there for around 15 seconds. This should transfer enough heat to loosen the part and allow you to remove it carefully.
Again, just be cautious with the heat, and avoid touching the metal directly while it’s hot.
