Inkplate 4 Tempera - Inkplate LVGL - Problem compiling example sketch
I was trying to get some examples of the Inkplate LVGL lib to compile but it always fails with the same message that I’m missing a header file driver/i2s_std.h
I installed the board definitions and the library in my Arduino IDE should I install something extra?
Hello sh33dafi,
It seems that you are using the old board definition
You can find a tutorial on how to download the newer board definition version on the following link (Section 2): Inkplate 4TEMPERA - Quick start guide | Soldered Documentation
I was able to replicate the compilation error when moving back to the old “Inkplate Boards” ver. 8.1.0 board definition. The new and improved board def is called “Soldered Inkplate Boards” ver. 3.0.0
