Inkplate 5 gen2 always-on modification via 0 ohm resistor
We need to modify an Inkplate 5 so it stays powered on whenever the device it’s connected to is powered on. We have soldering skills and can do the modification ourselves.
Originally submitted via email support on 10 April 2025. Migrated to the forum for community visibility.
To clarify: you want the device to be always powered on when connected via USB, and if there’s a momentary power loss, it should automatically power back on?
There is an on-board jumper you can solder together to accomplish this. Which Inkplate model do you have?
Yes, it should be on always when connected via USB, and if there’s a momentary blackout it should power back up on its own. We have the Inkplate 5 gen2.
Here’s how to do it:
It’s not technically a jumper but a 0 ohm resistor that is not placed. It works the same way though - just bridge the connection and Inkplate will be on when connected via USB.
