Inkplate 5 gen2 MicroPython driver has mirrored image and wrong dimensions
I bought an Inkplate 5 gen2 and am following the documentation to set up MicroPython scripts. The problem is there are no specific scripts for the 5 gen2, only for the Inkplate 5. The code works to some extent but the image is mirrored and I had to adjust the dimensions. I checked and in the Arduino repository there is a specific version for the 5 gen2. What exactly should I use if I’m using MicroPython to make everything work correctly?
Kupio sam inkplate 5 gen2 i pratim dokumentaciju za postavljanje micropython skripti. Imam problem s tim da nema posebnih skripti za 5v2 već samo za inkplate 5. Kod donekle radi ali je slika zrcaljena i trebalo je prilagoditi dimenzije. Provjerio sam i u repozitoriju za arduino postoji posebna verzija 5v2 pa me zanima što bih točno morao koristiti ako koristim micropython kako bi sve radilo kako treba.
Šaljem u prilogu fotografiju pokretanja networkExample.py skripte
Attachment omitted in migration: 1000012194.jpg
Originally submitted via email support on 9 January 2025. Migrated to the forum for community visibility.
I understand the situation. Another user reported the same thing, and due to project backlog we haven’t had time to update MicroPython for the new Inkplate 5 version.
You can try continuing to modify the Inkplate 5 driver, as you mentioned for the e-Paper resolution, and somewhere reverse the loop that iterates through D_ROWS and D_COLS. Unfortunately we’re not able to do that currently.
This fix for the MicroPython library should be relatively quick to make and is a reasonable request, but we really can’t get to it right now. I could look at it in about 2 weeks if absolutely necessary. Personally I’d also recommend the Arduino library.
Podzrav [name removed],
razumijem situaciju, jedan korisnik nam je isto ovo ukazao i zbog gužve s projektima (koja još uvijek traje) ukratko nismo stigli napraviti update micropythona za novu verziju Inkplate 5.
Možeš pokušati nastaviti modificirati Inkplate 5 driver, kao što si spomenuo kod rezolucije e-Papera i negdje preokrenuti petlju koja iterira kroz D_ROWS i D_COLS, što na žalost nismo u mogućnosti trenutno napraviti.
Preporučujemo korištenje Arduino library-a jer on ima kompletno sve feature za Inkplate i on nam je prioritet za održavanje.
Ovaj fix za Micropython library bi trebao biti relativno brz za napraviti i razuman je zahtjev, samo što trenutno stvarno ne stignemo i isprike na tom. Mogu pogledati tek za ~2 tjedna ako je baš potrebno. Osobno bi isto preporučio Arduino library.
Since I’m new to this, I’m not sure what the steps are to switch back to using Arduino. According to the MicroPython setup documentation there were steps 1-4. Now I’m not sure if I need to do something similar to switch back to Arduino.
Hvala na odgovoru,
Budući da sam nov u ovome, nisam siguran koji su koraci kako bih vratio postavke na korištenje arduina. Prema dokumentaciji za postavljanje micropythona bili su koraci 1-4, sad nisam siguran treba li nešto slično za vraćanje postavki na korištenje arduina?
You don’t need to adjust anything extra. Just follow the Arduino getting started instructions at Inkplate Get Started Page — Inkplate docs documentation and upload one of the Examples. That will overwrite what’s left in memory from MicroPython.
hvala na razumijevanju, ne moraš ništa dodatno podešavati, samo prati Arudino getting started upute Inkplate Get Started Page — Inkplate docs documentation
i uploadaj jedan od Example-ova :slight_smile: to će ‘pregaziti’ što je ostalo u memoriji od MicroPythona.
Nadam se da će ti korištenje Arduino softvera biti OK, i sretno s Inkplate projektom!
