I’m using the Inkplate5v2 with the Soldered Inkplate ESPHome custom component (https://github.com/SolderedElectronics/Soldered-Inkplate-ESPHome/tree/main).
I noticed my custom .yaml code stopped working after 1-2 hours or so. It was a lot of “ghosting” on the screen and when i opened the logs it was full of errors saying “[E][inkplate:588]: I2S DMA timeout — line not sent” many time per second.
I first assumed this had something to do with my .yaml but i later did a test with the example code on github “inkplate5v2_partial.yaml” and got the same issue. I let the code run with the log window open in ESPHome Builder and it also failed after 1-2 hours with the same spamming error message.
[17:50:14.461][E][inkplate:588]: I2S DMA timeout — line not sent
[17:50:14.463][E][inkplate:588]: I2S DMA timeout — line not sent
With the occasional
[17:50:14.356][W][component:421]: display took a long time for an operation (3986 ms), max is 2550 ms
[17:50:14.445][W][inkplate:148]: display_partial() skipped — busy (state 2)
I ran it twice, and both tests failed after roughly 1–2 hours with the same I2S DMA timeout errors.
Here is the exact code i used for reference:
esphome:
friendly_name: Inkplate 5 V2 Partial
on_boot:
priority: -100
then:
- component.update: my_inkplate5
esp32:
framework:
type: esp-idf
variant: esp32
external_components:
- source:
type: git
url: https://github.com/SolderedElectronics/Soldered-Inkplate-ESPHome.git
ref: main
psram:
mode: quad
speed: 40MHz
# WIFI / API / OTA
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
api:
encryption:
key: !secret inkplate5v2__encryption_key
ota:
- platform: esphome
logger:
baud_rate: 115200
hardware_uart: UART0
i2c:
sda: GPIO21
scl: GPIO22
frequency: 100000
pca6416a:
i2c_id: i2c_bus
address: 0x20
display:
platform: inkplate
model: inkplate5v2
i2c_id: i2c_bus
address: 0x48
pca6416a_id: inkplate_pcal
update_interval: never
lambda: |-
it.fill(COLOR_OFF);
it.filled_rectangle(0, 0, 1280, 720, COLOR_ON);
it.filled_rectangle(10, 10, 1260, 700, COLOR_OFF);
interval:
- interval: 10s
then:
- lambda: |-
static bool state = false;
state = !state;
id(my_inkplate5).filled_rectangle(400, 260, 400, 200,
state ? COLOR_ON : COLOR_OFF);
id(my_inkplate5).display_partial();
I also did a test (~8h) without any partial refreshes in the code that did not fail.
Has anyone seen this issue before? Could it be related to the partial-refresh implementation?
