I have 3 Inkplate 6 units that boot loop when trying to run them on battery while connecting to WiFi.
Originally submitted via email support on 11 July 2023. Migrated to the forum for community visibility.
To help diagnose the issue, can you gather some data via Serial to find out what’s causing the boot loop? Try writing the error code returned by the function to the display so we can see what it means.
Does the boot loop happen quickly after startup or does it take a while? If it happens quickly, it could be a power issue. If it takes longer, it could be a WiFi connection issue.
To better help diagnose this, I’ll need:
We have tested Inkplates with battery for many projects both with and without WiFi, and they typically work fine, so I’m interested in understanding what’s different in your setup.
