Inkplate 6 COLOR case battery size limits
I have an Inkplate 6 COLOR with the included case. The bundle came with a 1200mAh battery. Are there larger batteries available that would also fit in the case?
Originally submitted via email support on 16 March 2025. Migrated to the forum for community visibility.
The enclosure has a slot designed specifically for the 1200mAh battery. You could technically modify and re-print the enclosure to hold a larger battery with the same thickness.
The STL files for the enclosure are available here: Soldered-Inkplate-6-COLOR-hardware-design/OUTPUTS/V1.2.1/3D printable files at main · SolderedElectronics/Soldered-Inkplate-6-COLOR-hardware-design · GitHub
A larger battery might be possible in width and height (but not thickness), though the 1200mAh was the largest that fit in the pre-made design. If you want to use a larger battery, you could modify the enclosure by making it thicker or adding an add-on to accommodate it.
You can check the battery product pages for size specifications if you’re considering sourcing a battery from us.
